Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › ZANUSSI ZWD1271 RESETIING ITSELF
- This topic has 9 replies, 5 voices, and was last updated 15 years, 7 months ago by
admin.
September 9, 2010 at 12:22 pm #57136
Keymasterif you put the appliaance on to any wash / rinse or spin cyscle it runs for between a couple of seconds and a minute and then resets itself and teh start light flashes, we have tried the main pcb (right hand side) but to no avail, any ideas?
Simon
September 9, 2010 at 12:54 pm #329977Martin
ParticipantRe: ZANUSSI ZWD1271 RESETIING ITSELF
Usually when an error is detected, and it sounds like that may be the case, then both the ‘start’ LED and the ‘end’ should flash. Does the end LED flash as well?
When it runs, as you say, only the drain pump should at that point. Once an error in the circuit is detected it then throws up an error code. More often than not it’s either the water or dryer elements or the brushes that cause this.
Final question: Have you entered into the diagnostics cycle?
September 9, 2010 at 12:54 pm #329978pup
have checlk the heaters?
September 9, 2010 at 12:58 pm #329979admin
KeymasterRe: ZANUSSI ZWD1271 RESETIING ITSELF
Martin wrote:Usually when an error is detected, and it sounds like that may be the case, then both the ‘start’ LED and the ‘end’ should flash. Does the end LED flash as well?
only the start light flashes, and i dont have the diagnostic cycyle for this one
September 9, 2010 at 2:59 pm #329980blackandwhites
Check for low insulation on drier element.I also had a similar strange fault on one of these where the circulating pump was open circuit(wire snapped on tag)
September 9, 2010 at 9:29 pm #329981leavemetogetonwithit
Simon, there is loads on this in this forum. Just do a search e.g. “ZWD1* start flashing” tick find all terms. Or search for “40Megohm” 😉 . But can also be damp.
Mike.September 10, 2010 at 7:30 am #329982Martin
appleelectrics wrote:only the start light flashes, and i dont have the diagnostic cycyle for this one
Check your email Simon 😉
September 10, 2010 at 7:59 am #329983admin
only the start light flashes, and i dont have the diagnostic cycyle for this oneCheck your email Simon 😉
checked it but nothing there 😥
September 10, 2010 at 11:12 am #329984Martin
appleelectrics wrote:checked it but nothing there 😥
I sent it to: service@appleelectrics.com
September 13, 2010 at 8:45 am #329985admin
KeymasterMartin
Received – Many thanks
Appreciate all the assistance. -
