Zanussi ZWD1271w Start Button Won’t Work
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi ZWD1271w Start Button Won’t Work
  • #93760
    2200rpm
    The ZWD1271w machine powers up, all selections are possible but when pressing the start/pause button it doesn’t click & start the cycle as it would normally.
    It has no visible signs of damage etc & springs back normally.
    No error codes shown.
    Obviously it may not be that button but a connection to something else, any ideas on how to track the fault down so I can buy the correct spares?
    Thanks in Advance!
    #455467
    Re: Zanussi ZWD1271w Start Button Won’t Work
    Door lock is the first thing that springs to mind but on most machines I would expect an error code but can’t look that up till I am in front of a computer
    Child lock has it been put on by accident ?
    2200rpm
    Thanks Dave
    I don’t think a child lock is on that machine (I haven’t found it if there is).
    First thought I had was to wonder about the door lock, they are cheap enough to try one anyway I guess. Easy to fit?
    ***Update***
    Figured out how to get into diagnostics (start+reset & power up) & it comes up with E51 & 6 beeps.
    Not looking good. πŸ˜•
    #455469
    E51 is motor triac short circuit. It’s a small electronic switch on the board
    This fault can also be caused by a slight earth fault on the motor so before you do anything else I would remove the brushes and clean all the carbon dust off them then put them back and try again
    2200rpm
    OK thanks I’ll give it a shot πŸ™‚ πŸ™‚
