Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Zanussi ZWD1427OW washer/dryer
- This topic has 6 replies, 3 voices, and was last updated 11 years, 10 months ago by
Bramley.
June 6, 2014 at 10:59 am #80949
Bramley
ParticipantHi all, I called an engineer out a couple of weeks ago because when I switched on a program, the drum turned about three times then I got the finished noise (two bangs) and it stopped. Of course when he came it worked perfectly well, costing me a callout fee. Since then it’s been very temperamental. I did manage a quick wash this morning but when it stopped I didn’t get the beeps, it just went back to 30mins on the display. I couldn’t get it to fast spin afterwards.
At the moment the program times come up, the start/pause flashes but non of the programs will start at all…I’m not getting the ‘knock’ that I use to get to start it…there’s no error messages.
I know it’s had it but any ideas what the problem is and if it’s worth repairing …. it’s 6 years old but only gets used about once a fortnight.
Thanks FayJune 6, 2014 at 3:20 pm #414929Martin
ParticipantRe: Zanussi ZWD1427OW washer/dryer
Did the engineer check the pump? Did he check the heating elements? All of which can cause these common error problems.
June 6, 2014 at 11:00 pm #414930Bramley
Thankyou for replying. He didn’t check anything Martin, he was in the house about 5 mins. I was so shocked that the program started, I thought I must be going senile. Can the pump work intermittently before it finally goes because I managed a wash this morning? I’ll try it again in the morning I might just be lucky, I’ll try it on a hotter wash to see if the heater works.
June 7, 2014 at 4:47 am #414931captaincaveman1
Most likely the dryer element due to lack of use. an easy fix
June 7, 2014 at 7:59 am #414932Martin
Bramley wrote:I’ll try it on a hotter wash to see if the heater works.
We’re talking a faulty DRYER heater here that will affect the machine from the start even if you haven’t set a dryer cycle. At least checking the machine with an insulation tester is a fundamental procedure for an engineers visit. It can also be performed within the 5 mins the guy was in your house anyway and would have immediately shown a fault with your machine.June 7, 2014 at 9:21 pm #414933Bramley
Thanks CC1 and Martin for you help. That makes sense as the dryer has only been used about a dozen times and hasn’t been used at all in the last five years. Tried again today but it started then stopped within a couple of seconds. Thanks again both for the information I’ll get the engineer back out now that it has completely conked …. I suppose it’s like everything else …. use it or lose it!!…. have to do more washing in the future.
July 4, 2014 at 11:37 am #414934Bramley
Just to say ..you were both correct .. it was the dryer element .. thanks again …. all fixed!!
