Zanussi ZWD14581W1 fault code E9F
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi ZWD14581W1 fault code E9F
  • #71671
    boneym1960
    Hi there, help !!!! customer just phoned in with the above mentioned zanussi washer/dryer showing fault code E9F, new one to me, anyone know what this one might be cant seem to find it in zanussi faualt code section…..regards….dave(self employed appliance engineer)
    #381884
    Dragan
    Re: Zanussi ZWD14581W1 fault code E9F
    Hello,
    E9F means communication error between PCB and Inverter,
    Check wiring,PCB and inverter.
    Dragan
    #381885
    boneym1960
    Cheers Dragen for advice on fault code,went out to it today and by component test and deduction put the fault down to a faulty motor inverter as its got a three phase induction motor on this model similar to those used on the higher end Merloni machines that suffer similar problems especially if suds lock/ overload on rinse/spin,I normally get these repaired or exchanged by E.M.W electronics. don’t know if they cover these LUX brands though, any idea of repairer/exchange or is it just new only….Regards….Dave (engineer)
    #381886
    bazza500
    Dave if you’re a self employed Domestic Appliance Engineer why not apply for trade access? There is a lot more info and help in the trade sections.
