Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Zanussi ZWD14581W1 PCB replaced but still not quite there
- This topic has 11 replies, 2 voices, and was last updated 6 years, 3 months ago by
Seret.
December 17, 2019 at 10:43 pm #96897
Seret
ParticipantHi,
I’ve just had the PCB die in my Zanussi ZWD14581W1 washer/dryer. It was definitely the PCB, there’s a burned out component on the old one I removed.
I ordered the replacement PCB from Zanussi direct and have just fitted it. Happy days, the machine now powers up. However, when trying to start a wash cycle it just stops after a few seconds with the start button flashing.
I’ve double-checked all the connections on the board and everything is plugged in properly. Does the PCB need any kind of config? I feel like I’m 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the way here and that I’m just missing something.December 17, 2019 at 10:48 pm #465270electrofix
Moderatorwhat part number did you fit ?
and what is your full pnc number ?want to check you have correct part also is the start button flashing a sequence ?
December 17, 2019 at 11:00 pm #465271Seret
ParticipantI fitted this part: https://shop.zanussi.co.uk/laundry/washing-machines/electronics/configured-electronic-ewm-2500/p/973914604322029
To a ZWD14581W1 (914604322 02), this was the part the Zanussi site said was compatible.The start button isn’t flashing any code and there are no errors on the panel.
December 17, 2019 at 11:09 pm #465272electrofix
Moderatoryes its the correct part but did you find out why the old one burnt out ?
December 17, 2019 at 11:32 pm #465273Seret
ParticipantNo, but this is the damage on the board if it helps:
December 17, 2019 at 11:48 pm #465274electrofix
Moderatortrying to read nombers off blown chip
what is the connector number in the fore ground
December 17, 2019 at 11:55 pm #465275Seret
ParticipantThat’s J1 on the left and J2 on the right. The chip that’s blown up is TYACS2
The damage to the frame of the connector was me when I was dismantling it, they were on effing tight and since I was chucking the board I didn’t bother being too gentle with it. It’s possible I broke a connection in the plug while doing this perhaps, I may bell the wires out if I can find a circuit diagram.
December 18, 2019 at 12:08 am #465276electrofix
Moderatordoes the door lock
think that chip may feed it ?
the key here is that chip but what worries me is there is a faulty component it feeds that could well blow your new board
that chip is an electronic switch we need to find out what it feeds. if you know what connector it feeds out on i should be able to find out where it goes
DaveDecember 18, 2019 at 5:58 pm #465277Seret
Participantelectrofix wrote:does the door lock
Yup.
See here for a short video of how it’s behaving: https://youtu.be/1XEqCbGJhVU
Yes, I was worried that something had blown the chip on that board, but the new one is in there and there’s no smoke coming out of it yet…
Assuming that the connectors adjacent to that chip are related to it, yes the wires do go down to the door interlock.
Appreciate your help on this, btw!
Edit:
Just pulled the door lock out (it felt slightly warm tbh?) and the plug on it is showing some scorching. I thought I might have found a smoking gun, but the wires back to the board are still only showing 0.1 to 0.2 ohms and the door does lock.
December 18, 2019 at 9:45 pm #465278electrofix
Moderatorlong shot have you checked the motor?
dave
December 20, 2019 at 2:51 pm #465279Seret
Participantelectrofix wrote:long shot have you checked the motor?
dave
Getting about 23ohms through the motor and no short to earth.
I have noticed something though: the Electrolux part number on the PCB Zanussi supplied isn’t an exact match for the one I removed:
Out
InIt’s physically the same and shows the same “boot ver” on the software side but could the different part number mean they’ve actually sold me one not programmed correctly for this machine? Their site assured me it was the right part…
December 20, 2019 at 4:26 pm #465280electrofix
Moderatorcheck part number earlier and was correct programmed unit. assume you checked the part no on the box
as for motor assume you checked
Armature
field coil
Tachometeryou need readings through all of them
some field coils have 3 tappingsDave
