Ditto, only my machine is an AEG, 6100 Dig. enr 605 648 372.
Cust complaining of taking too long to finish and I noticed it stuck on 47 for 10 -15 mins, before I aborted wash. Also intermittently won’t start; does initial pump out and then reverts back to start light flashing. Got that prob. on a Zanussi FLE1215W too….
Board fault maybe?
HAD THIS FAULT ON AEG AND ZANUSSI ALWAYS ON 47 MINUTES .IS A HEATING PROBLEM U WILL NORMALLY FIND HEATER TESTS OK IN WHICH CASE THE MAIN BOARD IS FAULTY…. OR SO I FOUND.. STANGE THING IS I NEVER GOT AN ERROR CODE SHOWING RELATED TO THIS,HOPE THIS HELPS
Thanks for that. Will try a new heater and see what happens. Any ideas on the not starting bit, where the door locks, pump runs and then start light flashes again as if prog. paused/not started?
