need help with this one lads after 2 hours i`m pulling my hair out what little i`v got. ! You can start any wash prog after 2-3 min m/c gose back to start time the start/pause light flashes m/c stops. on entering diognistics and you get various fault codes you can also only get the pump cycle to run for about 10sec its not the board as i have already changed it.(same fault befor and after)
