ZANUSSI ZWD1471S
  • #38283
    PGS
    Called to this m/c today for no dry fault. No fault codes in memory, and no fan motor although there was 35v to terminals, no pump, no heat only forward/reverse motor action. Any ideas guys. PS Washing m/c works 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}.
    #258324
    DentedPorsche
    Re: ZANUSSI ZWD1471S
    Hiya,
    If there’s water coming in I’d be guessing at the dryer NTC in the condenser hose, although it should bring up an error code.
    Brian
    #258325
    PGS
    Would the faulty NTC cause only motor action. There is no water coming in on drying cycle,only on wash cycle.
    #258326
    DentedPorsche
    If there’s no water coming in then the fan shouldn’t run and the heater shouldn’t come on. However, again, it should register an error code.
    #258327
    PGS
    Brian thats exactly what is happening but display shows time to end only.
    #258328
    BobHope
    Hi Paul,
    have you checked the water soliniod valve ?
    quite a common problem.
    Bob.
