Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › zanussi zwd1471w 914601116-00
- This topic has 8 replies, 5 voices, and was last updated 15 years, 1 month ago by
funkyboogy.
March 5, 2011 at 9:14 am #61476
funkyboogy
Participant1st fault e12 – triple valve dryer coil o/c
changed valve – dryer worked a treat , got a call back washing side now faulty ..
e36 anti boil pres switch – pcb ? appliance would start – fill go for about 1 minute and then start led would flash as if appliance was paused ..
switch of -on and would do the same – as above
didnt have the anti boil switch – so changed what i had pcb …
still same prob .. ie start fill wash for a min and then start led flash ..
anyone had this ??
im going back with anti boil pres swi ..
cheers ally
March 5, 2011 at 11:03 am #346321Martin
ParticipantRe: zanussi zwd1471w 914601116-00
funkyboogy wrote:anyone had this ??
Not me but most E3? errors on these turn out to be water heater earth leak, at least that’s what I’ve found anyway. HTH?
March 5, 2011 at 11:05 am #346322funkyboogy
hi martin its was e36 .. but i will check heater
cheers
March 7, 2011 at 12:19 am #346323scientist
Go straight for the heater. Common fault on the Zanussi washer dryers with an E36. I’m betting it’s the dryer element that has the earth leak. Just disconnect this element and test the unit. Seems to happen to the dryer heater when the customer isn’t using the dryer that often you’ll see rust on the element but not always.
March 7, 2011 at 12:56 pm #346324funkyboogy
cheers , will take dryer ele as well
is it just me – but every time i do a simple job on a zanussi it turns into a 2-3 visit head scratcher ?
ally
March 7, 2011 at 1:10 pm #346325Martin
funkyboogy wrote:is it just me – but every time i do a simple job on a zanussi it turns into a 2-3 visit head scratcher ?
It’s the ‘Zanussi effect’ Ally, didn’t you notice how thin I was on top? In fact in my case it started when I was a young buck like you! 🙁
March 7, 2011 at 10:03 pm #346326Seamy
E36 on w’dryers is normally low insulation on dryer heater.
March 8, 2011 at 8:38 am #346327Martin
There’s an echo in here……..!!! 😛
March 8, 2011 at 11:11 am #346328gandh1
gggoooddd cchhaanncceee iiiiiitttssss ttthhhheeee dddrryyyyerrr eeelllleeemmmeenntttt
had 5x now in last 6 mths
