Re: zanussi zwd1471w machine wont start
heater element failures wont normally stop these locking the door chris, they will start the test run for a few seconds at least before stopping.
every drier element low insulation failure ive been too will wash for a few mins, then abort,
on this generation, open circuit wash heaters will cause constant filling on test run,
im with martin and id be looking at carbons, solenoid, or interlock tbh, and probably pcb for a triac blowout too.
id suggest door assembly, pretty sure these didnt have the flappy pull out semi-circle door handles tricitys had which would occasionally come out of alignment, iirc instead they had the shielded handle levers which rarely play about.
diagnostics and connect mediaTOR are your friends for this one 😀
