Hi all,
Have just started to use our new Zanussi washer/dryer. Every wash so far has been interrupted with beeping and an E10 error code on the display. 🙁
Manual says there may be a problem with the inlet hose, but I’ve checked for kinks etc and can’t see anything obvious. The supply tap is fully open also. The wash completes ok if I clear the fault by pressing the start button.
Can anyone suggest anything else worth checking before I give the service centre a call?
Many thanks,
Stanners
