Zanussi ZWD1472S – Pauses on start and E40 error
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi ZWD1472S – Pauses on start and E40 error
  • #74164
    donal
    Hi All,
    I have a Zanussi ZWD1472S Washer/Dryer. The problem I am having is previously it was pausing on any wash selected (I tried different washses but to no avail). I could turn if off and back on a few times to get around this issue.
    I have not used the unit in a few weeks and no matter what I do today I keep getting E40 displayed on the front panel.
    Somebody mentioned replacing the door lock interface so I picked up that part today. I was wondering if replacing this part might help? Also how would I go about replacing this?
    Thanks in advance.
    #390229
    Seamy
    Re: Zanussi ZWD1472S – Pauses on start and E40 error
    E40 would point towards to door interlock fault, replacing the part should help, you would replace it by switching off the power to the appliance, taking off the door gasket from front of appliance to allow access to door lock, remove screws securing interlock, remove cable from it fit cable to new one & fit in reverse order.
    If this is something you can’t manage you should find an engineer you would be happy to do it for you.
    #390230
    donal
    Thanks for the reply.
    I got an engineer out to replace the door lock interface.
    Now I cannot get around the issue whereby no matter what wash I put on the machine pauses/stop after a couple of seconds. I have tried numerous times to turn off and on and try again but to no avail.
    Is it the system board now thats gone?
    Thanks in advance for any help 🙂
    #390231
    Your engineer needs to call back and check the connections to the door interlock and the main Power Board (PCB) as the fault lies in that area for sure.
    #390232
    donal
    Thanks Martin for your reply.
