Zanussi ZWD1662 “stopping mid cycle”
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi ZWD1662 “stopping mid cycle”
  • #83093
    subs
    Prod 914603211/00
    Customer said machine was cutting out mid cycle. I checked everything and it had the common insulation fault on the dryer element. I changed this and put it on a short wash which it completed. I then get a call back saying its still cutting out. Went back and on the test program it comes up with E22. Is this not draining? Or not filling on dry cycle?
    Either way its doing both correctly it seems ( tested valves and draining ). Also went through a short wash again while I was there.
    Any ideas what the problem is?
    Subs
    #421735
    Re: Zanussi ZWD1662 “stopping mid cycle”
    I’m not sure why this would come up “mid-cycle” as usually it signifies that the dryer condenser is clogged to buggery.:(
    #421736
    aqualectric
    Re: Zanussi ZWD1662 "stopping mid cycle"
    Also check the new drier element for earth leaks – not unknown for the new to be as bad as the old!!
    #421737
    Subs changed the element Steve.
    #421738
    aqualectric
    Yes, I know Martin…. read my post again. I said check the NEW element for earth leaks…… :rolls:
