Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Zanussi ZWD1662W needs PCB + interface & door switch
- This topic has 4 replies, 3 voices, and was last updated 15 years, 5 months ago by
portmoon.
November 1, 2010 at 12:45 pm #58470
portmoon
ParticipantHello,
I have a Zanussi ZWD1662W washer dryer that needs a new PCB + interface & door switch (see below for explanation).
Does anyone know where I could get these parts or what a reasonable price would be for parts and labour?
I’m in Headingly, Leeds by the way if anyone out there would be willing to do the repair
Thanks in advance
portmoon– The reason I know I need a new PCB + interface & door switch is that I (foolishly) had a Domestic & General washing machine insurance policy. Like an idiot I just renewed it every year without reading the small print, which said that once my machine is 3 or more years old they’ll only refund 30{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the cost of a new one if it’s deemed uneconomical to repair. Not only that but I have to buy my new machine from their approved retailer (Comet) – which is not the cheapest. Anyway the engineer came out and told me what’s needed to fix it. So I’m thinking it may be cheaper just to write off the cost of the policy for the last 3 years and just get the machine repaired, depending on what it costs.
November 1, 2010 at 12:47 pm #334633portmoon
ParticipantRe: Zanussi ZWD1662W needs PCB + interface & door switch
Just found this;
http://www.zanussi.co.uk/node123.aspx?s … e=ZWD1662W
the cost of the parts alone comes to £180 so maybe I’d be better just getting a new machine, unless anyone can do it for less!?
November 1, 2010 at 2:03 pm #334634odom
Might be worth getting a second opinion from a local independent repairer as to whether you actually need a new PCB, interface AND door lock – the first two especially are expensive parts to buy on the recommendation of someone who’s not prepared to fit them.
Unfortunately this machine has a useless Electrolux board so the door lock taking out the board isn’t beyond the realms of possibility, but I’ve never known the interface board go too.
If those are all gone to be honest I’d call it a day and spend the money on a decent Bosch or ISE instead.
November 1, 2010 at 2:31 pm #334635portmoon
Thanks for the advice – I’ve decided to get a local repairer to come out and have a look. I’m a bit suspicious that they just said all those parts needed replacing so that they could get the call out fee without having to do any work. The insurance company probably get commission from Comet as well so it’s in their interests to get you to buy a new machine.
November 5, 2010 at 11:08 pm #334636Bluntblade
I had same problem, have a policy with Dom @ Gen on washing machine and the machine stopped working following strange noise on 14 minutes remaining. Called out engineer through insurers who fitted new carbon brushes which didn’t work. Machine gave error code reading relating to motor, engineer phoned to obtain authorisation for new motor, pcb and control module – all approximately £300. Dom & Gen declined and wrote machine off. They wanted £330 for a £319 machine via Comet.
I decided to have a look myself, cheap motor on ebay etc, so removed back of machine to remove motor and found that belt had come off, questioned engineer who advised he took motor out and belt off to replace brushes (all this work in 5-10 whilst I was tilting machine – I don’t think so). So why when he put new brushes in didn’t he put belt on. Anyway drum didn’t spin and he took new brushes out and machine written off. I bought new brushes and put belt back on – machine now works sweet as a nut. Annoying thing is I could of shed out £300 when no need.
Makes you wonder whether these companies are working hand in hand. I’m awaiting outcome.
