zanussi ZWD1680w
  • #37116
    mjhservices
    The problem with this is a bit odd. When you put it on for tumble drying the digital timer counts down each minute every 20 seconds and it does not heat. I have checked the elements and thermostats and the blower motor and pump is okay.
    Regards to all
    Mark
    #253606
    DAR01
    Re: zanussi ZWD1680w
    Is it putting water into the condenser?
    Mike 😕 😕 😕
    #253607
    mjhservices
    DAR01 wrote:Is it putting water into the condenser?
    Mike 😕 😕 😕
    Dont know, how would this cause this problem then?
    Mark
    #253608
    mjhservices wrote:Dont know, how would this cause this problem then?
    Mark
    The inlet valve to the condenser may be open circuit causing the programme to shut down. Also a faulty condenser NTC can cause the same symptoms. 😉
