zanussi ZWD1680W
  • #44766
    LittleMan
    This washer dryer will flash e10 after about 10 min on drying prog
    could this be the condensor inlet valve
    can any one help please
    Many thanks Les
    #282239
    Specialist01269
    Re: zanussi ZWD1680W
    Hi: E10 is the user error code for cycle paused, due to any of the following:
    1) Poor water pressure
    2) Faulty inlet valve
    3) Fault in pressure system or switch
    4) Bad interconnection wiring
    5) PCB faulty
    Normally in that order, HTH[/img]
    #282240
    The coils on these valves can measure OK when you check them but go o/c when they warm up. Common problem; must be ’cause I’ve seen it twice.
    Mike.
