Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Zanussi ZWD71460 E10
- This topic has 3 replies, 2 voices, and was last updated 8 years, 3 months ago by
JAILLUD.
January 6, 2018 at 6:44 pm #92996
JAILLUD
ParticipantHello everyone.
I have had a route around and can’t seem to find anything specific for my washer dryer model number. However I believe the problem is with my inlet valve?
I get the E10 error code whenever I try to run wash or dry cycles. I have taken the lid of and its a triple valve as far as I can tell.
PNC: 914603902 (00)
SN: 54700038There are numbers on the actual inlet valve itself not sure if they’re useful or not.
33690171
132518841
308/15/09
Will replacing this valve definitely fix my issue? And is there any way to fully reset the washing machine so the chip doesn’t get confused and still give me the fault or is that not an issue?Also, while I’m inside the machine is there a way to rip out the device that makes the horrible noise when its done? :eeek: :eeek:
Thank you very much for any help or advice.January 6, 2018 at 7:21 pm #452822electrofix
ModeratorRe: Zanussi ZWD71460 E10
you are seeing the customer error code and there is actually
there is E11 too long to fill can be slow fill rate or water is going out the outlet hose as its filling and machine times out
E12 water difficulties on the drying cycles
E13 water leakage global time out. fill takes too long
yes the fill valve is one of a number faults this could be including blocked valve filter, tap not fully turned on etc
valve part no listed as 1325188413
January 6, 2018 at 7:39 pm #452823JAILLUD
ParticipantRe: Zanussi ZWD71460 E10
Thank you for your reply.
So as that part you suggested is only £16, its worthwhile just trying it out? Is there anything I should be aware of when replacing it? What do you suggest if the valve isn’t the problem?
January 6, 2018 at 8:42 pm #452824electrofix
before you change it
check the tap make sure its full on and working. a lot of quarter turn taps seem like they are on but they are only on half way due to wear in the plastic knob. check the outlet hose. check when machine is filling that no water is coming out the outlet hose.
take the inlet hose off the back of the washer and there is a filter on the entrance to the valve check its not cloggedreplacing valve should not be a problem as long as all the connections and wires are in the correct place. take pictures before you start
