Zanussi ZWD81683NW Washer/Dryer Dryer not heating
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi ZWD81683NW Washer/Dryer Dryer not heating
  • #95931
    Twoten
    I am looking at the above machine PNC:914604535/00.
    When set to dry the pump runs then the inlet valve operates and the machine takes in water for about 1 minute. Then the fan runs but no supply to the heater or cut out stats.
    The cut-out stats are closed circuit
    NTC on the heater box is 4.9Kohm
    NTC on back of tub reads 4.5Kohm
    Wiring from PCB to NTC’s and element reads OK
    No insulation faults.
    Elements OK
    I have tried to find a way to access the diagnostic information, so far no luck on this.
    Any advice/help would be appreciated.
    #461771
    assume you have checked for this then
    can get you tech if needed just need email address
    Twoten
    Hi Dave,
    I’ve had this on a machine before. I tested the NTC from the PCB so assumed the wiring harness to the NTC was OK. I also carried out a visual inspection but not under the tape so it’s possible the wire could be giving an intermittent fault.
    The user didn’t report a fault code either.
    If you can send the tech info on how to get into the diagnostics it would be appreciated, at least I can see if there was a fault code.
    I will PM my email address to you.
    Thanks.
    #461773
    sorted
    Twoten
    Hi Dave,
    Having accessed the diagnostics I found the last error was an E73 as you suspected.
    Traced the wires from the NTC and found there was a fracture inside the insulation which is why I still had a reading from the PCB when tested.
    I will get the replacement harness’s on order.
    Thanks again Dave.
    #461775
    no probs m8 anytime
    glad u sorted it
    you have learnt a bit more today
