zanussi zwf 10020 w door light on
Home Forums Public Support Forums Help And Support Washing Machine Help Forum zanussi zwf 10020 w door light on
  • #54136
    slyp98
    hi all have this machine ,stopped half way through cycle door will open all the time the door light is on always , took off the door switch seems to be sticking can operate the switch mechanicaly but it doesnt turn the light off wont drain or resume a wash any clues fellers
    #318548
    slyp98
    Re: zanussi zwf 10020 w door light on
    anyone????
    #318549
    Try a new door interlock, Part No. 1260607047
    #318550
    slyp98
    cheers phidom, i was looking at other similar posts which were pointing in the direction of motor brushes , so i wasnt sure 26.50 for an interlock here but im sure brushes are not too dear also thanks again
    #318551
    slyp98
    ok fitted new door intelock , and door locks now so thats good ,m/c was stopped mid cycle so is full of water switched to drain and pressed start .. nothing 10 mins nothing , bailed out water with jug as much as i could and restarted on drain cycle still nothing , opened filter and drained rest of water , restarted but i forgot it was on drain cycle and guess what … it started to drain ???? i let it finish and started a wash cycle, after 15 mins i stopped it and turned the switch to drain .. once again nothing so i repeated the above process once again ,any clues ????
    #318552
    kuango
    Just wondering if you checked the capillary tube connected to the pressure switch. Overtime it can rub on metal work and form a pin hole in the rubber. If this does not operate in the manner it was intended it can cause the odd symptoms you are experiencing.
    Remove the tube and blow in it to pressurise it.
    If that checks out, connect the tube to the pressure switch and check that the diaphragm acts on the switch. You need a multimeter to bell out the switch connections.
    If you don’t understand that then call out a qualified repair engineer.
    Isolating the appliance from the electricity mains socket by removing the plug from the socket will prevent almost certain death. You have been warned.
    #318553
    slyp98
    i take it its the tube that runs from under the tub up to a blue round switch under the top cover rear right hand side 8mm diameter with 2 pieces of sponge around it for protection , when i blew into it i could feel and hear water gurgling at the other end , i forgot my multimeter so i just connected it back up , i dont have an electrical schematic do you know which wires bridge out the switch for operation ? cheers kuango
