Zanussi ZWF 1010 – PNC914780743 00 – Replacing Bearings
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi ZWF 1010 – PNC914780743 00 – Replacing Bearings
  • #38360
    dugidee
    Sorry guys but I’m a newbee looking for advice – I promise though to feed back any help I can afterwards, based on my limited experience.
    The bearings in my 3 yo Zanussi are shot already and I’m considering having a go at replacing them. I’m an aircraft engineer so, arguably, have the experience required to hack the job but am having problems sorting out the best way to go about it.
    Can anyone tell me if my machine has a split drum and therefore, do I have to remove the whole lot to do the job? If so what is the best orientation for the machine to make life easiest – right way up/on its side/upside down/on the floor/up on a bench?
    Any helpful advice gratefully received!!
    Doug
    #258608
    helo_75
    not THAT bad, just time consuming
    top off
    split cabinet
    remove back weight
    remove fill hose
    unhook door seal, take off motor, and wiring (make wiring diagram first)
    remove sump hose
    take pins out of suspension legs
    pull sprigs off top of cabinet (v. heavy)
    pull tub out, split tub , by undoing bolts
    take off pulley, pull out drum, change bearings, reassemble in reverse order
    take your time and be methodical, and youll be ok
    hope this helps
