Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Zanussi ZWF 12070W Banging Then Won’t Spin
- This topic has 25 replies, 5 voices, and was last updated 13 years, 10 months ago by
pollys13.
June 10, 2012 at 8:10 am #69867
pollys13
ParticipantHi all,
Yesterday I was lucky enough to go and collect the washer from someone who was kind enough to put it on Freecycle. The lady said it started to bang then stopped spining. Is three years old she has a husband and two small children. My old washer we removed the drum, bashed out the old bearings put in new ones and worked a treat for a couple of more years but is now totally knacked.
Would I be right in thinking that the bearings in the Zanussi need to be replaced? Can I get an online user manual for it?
Any guides on opening it up and removing drum etc in case we can’t fathom how to do it?
Cheers.June 10, 2012 at 9:42 am #376235Martin
ParticipantRe: Zanussi ZWF 12070W Banging Then Won’t Spin
pollys13 wrote:Any guides on opening it up and removing drum etc in case we can’t fathom how to do it?
This little Italian gem comes out of their factory in Spain oddly enough. So first off, and with some flamenco music playing in the background, you’ll need to remove the back panel, the top panel, the motor, the shock absorbers and then lift the whole tub out of the top!
It’s all downhill from there and quite obvious what to do next. Are you up for a challenge?
Final words of advice: Stay off the sangria ’til its all back together and working again! 😈
June 10, 2012 at 11:37 am #376236pollys13
” Are you up for a challenge? ” Oh yes 🙂 In for a quid in for a pound as it were 🙂 One slight little thing though, I’ve been reading about the, ” You can’t replace the bearings.
The drum is plastic welded and doesn’t come apart.” ???
Thank you.June 10, 2012 at 11:47 am #376237kwatt
KeymasterRe: Zanussi ZWF 12070W Banging Then Won’t Spin
We’d need the PNC number from the rating plate to tell you for sure but yes, there are versions of that model that have sealed tanks fitted that you cannot replace the bearing on. 🙁
You can read more sealed tanks them here:
http://www.ukwhitegoods.co.uk/help/buyi … -care.html
June 10, 2012 at 12:15 pm #376238pollys13
Um interesting about sealed drums. My old Hoover Aquarius DF61
lasted years, I bought it in 1997. Was still going strong up till about 6 months ago, but the drum split and cracked, couldn’t tape it up any more, started to…. shred the clothes 🙂
Where do I find the PNC number?
Cheers.June 10, 2012 at 12:26 pm #376239kwatt
PNC is on the rating plate.
June 10, 2012 at 1:19 pm #376240iadom
ModeratorZanussi ZWF 12070W Banging Then Won’t Spin
Hoover Aquarius DF61???????
Aquarius is a Hotpoint brand name and a DF61 is a dishwasher.
June 10, 2012 at 1:41 pm #376241pollys13
iadom wrote:Hoover Aquarius DF61???????
My mistake, washer is a Servis Auto 600 the Hotpoint is the dishwasher, are next to each other.June 10, 2012 at 1:45 pm #376242pollys13
kwatt wrote:PNC is on the rating plate.
There are several numbers on the rating plate.
Ser.N. 72600157
Pr.N. 914216104 (00)
and a number under a barcode
91421610472600157100June 10, 2012 at 2:17 pm #376243kwatt
Yes, it’s a sealed tank I’m afraid so you cannot change the bearings. And, a new tank assembly is about £145 plus VAT and shipping, so near enough £200.
June 10, 2012 at 3:32 pm #376244pollys13
kwatt wrote:Yes, it’s a sealed tank I’m afraid so you cannot change the bearings. And, a new tank assembly is about £145 plus VAT and shipping, so near enough £200.
Oh dear, well at least I won’t have to find my club hammer 🙂
Thanks anyway mate.June 10, 2012 at 3:49 pm #376245Allsorts
I would check the Motor brushes… I had the same report from a lady in Chester a few days ago and thought exactly the same as you… When I got there it was purely motor brushes on their last legs, making an intermittent connection they where causing the drum to hit the side of the machine.
You can check for movement in the inner drum and noise level on spinning by hand to assess the state of the bearings.
June 10, 2012 at 7:31 pm #376246pollys13
Allsorts wrote:I would check the Motor brushes… I had the same report from a lady in Chester a few days ago and thought exactly the same as you… When I got there it was purely motor brushes on their last legs, making an intermittent connection they where causing the drum to hit the side of the machine.
OK thanks I’ll give it a try and let you know.June 12, 2012 at 10:07 am #376247pollys13
We just got it out of the car with the sack barrow. We spun the drum, yes is the bearing. My brother in law is going to get one of his star keys to take that metal wheel off the back of the plastic drum. Are we not able to drill out the old bearing in bits, then up end the drum and empty the bits out and then bang in a new bearing from the outside?
Cheers.June 12, 2012 at 10:23 am #376248kwatt
Nope, there’s a front and rear bearing and you cannot replace either with the drum shaft in situ as well as the front water seal. It is not possible to replace bearings without removing the inner drum from the outer tank.
