Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Zanussi ZWF 12070W Banging Then Won’t Spin
- This topic has 25 replies, 5 voices, and was last updated 13 years, 10 months ago by
pollys13.
June 12, 2012 at 2:09 pm #376249
pollys13
ParticipantRe: Zanussi ZWF 12070W Banging Then Won’t Spin
kwatt wrote:Nope, there’s a front and rear bearing and you cannot replace either with the drum shaft in situ as well as the front water seal. It is not possible to replace bearings without removing the inner drum from the outer tank.
OK thanks.June 12, 2012 at 2:13 pm #376250pollys13
OK thanks. Are there any washing machines around the £300 price range that can have the bearings replaced by a a DIYer?
Cheers.June 12, 2012 at 5:52 pm #376251kwatt
KeymasterRe: Zanussi ZWF 12070W Banging Then Won’t Spin
Not so much now.
Many cheap washing machines are designed to be throwaway items now and anything under about £300 considered to be “budget”, i.e., cheap.
Mid range, up to about £600 are a bit better but you need to watch what you buy.
Top end stuff usually isn’t a problem but then, they break a lot less as well.
Don’s your man for that question though of what’s good or bad in the budget stuff now but, without opening the washing machine up and having a look you probably won’t know unless you have a specific model number we can look up.
June 12, 2012 at 8:04 pm #376252pollys13
kwatt wrote:Not so much now.
OK thanks very much.June 13, 2012 at 6:48 am #376253pollys13
pollys13 wrote:
kwatt wrote:
Not so much now.Many cheap washing machines are designed to be throwaway items now and anything under about £300 considered to be “budget”, i.e., cheap.
Hi again,
Would a Zanussi ZWF1631 W tub & drum fit into my Zanussi ZWF 12070W?
Thanks.June 13, 2012 at 7:11 am #376254kwatt
No idea but, I’d doubt it.
June 13, 2012 at 7:30 am #376255Martin
pollys13 wrote:Would a Zanussi ZWF1631 W tub & drum fit into my Zanussi ZWF 12070W?
The suspension springs differ.
Tub depth differs
Front bellows differs
Tub outlet differsBut with a bit of bodging anything is possible I suppose. Depends on how determined and resourceful you are I guess. If someone can fit a jet engine into a VW Beetle then a simple matter of fitting a slightly different tub from one old scrap washing machine into another scrap washing machine should be a breeze. :clown:
June 13, 2012 at 9:29 am #376256pollys13
Martin wrote:
pollys13 wrote:
Would a Zanussi ZWF1631 W tub & drum fit into my Zanussi ZWF 12070W?The suspension springs differ.
Tub depth differs
OK.June 13, 2012 at 9:45 am #376257pollys13
pollys13 wrote:
Tub depth differs
OK.
What were the production years for the Zanussi ZWF1631 W
Cheers.June 13, 2012 at 9:52 am #376258Martin
pollys13 wrote:What were the production years for the Zanussi ZWF1631 W
From 2005 – 2007. Fine vintage years. Made from their factory in Porcia (just north on Venice) in fact.
June 13, 2012 at 11:31 am #376259pollys13
Martin wrote:
pollys13 wrote:
What were the production years for the Zanussi ZWF1631 WFrom 2005 – 2007. Fine vintage years. Made from their factory in Porcia (just north on Venice) in fact.
Um, 🙂 OK thanks. -
