Zanussi ZWF 12070W Continuous pump
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi ZWF 12070W Continuous pump
  • #46009
    PeteWilson
    Hi all,
    Just been to a Zan ZWF 12070 Programmes O/k Lights O/k, but when you press start all it does is drain forever. Any Diagnosis Mode available or any ideas?
    Pete
    #287925
    Re: Zanussi ZWF 12070W Continuous pump
    Before condemning the PCB just check out the motor and the heater? If either are faulty then the programme will only pump and not start. 😉
    #287926
    Madmac
    Attended a late zan today, cant remember mod but continued pump running was what i was faced with, refused to do anything else.
    Drum was totally empty as far as i could see, bit of a head scratcher 😕
    pulled press sw pipe off & off she went.. turns out ball float in sump had split in half & was keeping press sw pressurised. Machine obviously couldnt start till it detected a clear sump. Worth a look 😯
    #287927
    helo_75
    only it wouldnt contiuously pump
    pcb, fitted loads of em for that fault
    #287928
    PeteWilson
    Thanks for your replies
    It was PCB fault
    Cheers
    Pete
