Zanussi zwf 1421w 914521003/00 wont play nice
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi zwf 1421w 914521003/00 wont play nice
  • #60724
    Johnnyboy
    Hi guys I removed a key from the tub of this thing yesterday by removing the heater and fishing it out, now it wont work I cant access diagnostic , when any prog is selected it takes in water washes for 2 mins then abandons wash, the heater has continunity and the ntc is reading 12.5 ish, booby trapped or just order a heater, cant even select spin on its own, the usual it was alright before you worked on it but I never checked it was.
    Cheers Johnnyboy
    #343353
    neilsukwg
    Re: Zanussi zwf 1421w 914521003/00 wont play nice
    What was the initial enquiry from the customer for?
    Did the customer ring about a noise or something else?
    Have you meggered heater etc?
    #343354
    Johnnyboy
    there was a garage key stuck between the two drums,
    #343355
    Specialist01269
    Definately need to Megger the Heater, if there’s any leakage they do all sorts of weird things.
    #343356
    Seamy
    Any lights flashing a fault code when it stops?
    #343357
    Johnnyboy
    error 71 but tried new ntc still the same
    #343358
    Johnnyboy wrote:error 71 but tried new ntc still the same
    Tried new NTC?….That is part of the heater, so, next question, did you change the heater at the same time,?
    (You stated earlier that the heater in question had “continuity” so is it possible you haven’t checked its insulation resistance with a Megger?)
    #343359
    Anything under 40 Megohms, and the programme will be interrupted.
    Mike.
    #343360
    bigchrisoioi
    daft one …u havnt plugged the double heater wire into the ntc double connection in reverse?
    #343361
    Johnnyboy
    Thanks everybody all sorted
    Doh!!! Schoolboy error, mixed up the ntc and heater connectors. The NTC I tried was from another element just swapped round, dead quick but if the wiring was wrong it still wasnt going to work. Cheers.
    #343362
    Specialist01269
    Naughty Johnny, take 100 lines: I must not make mistakes 😛 🙂
