Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Zanussi ZWF 1430 Drum won’t turn
- This topic has 9 replies, 3 voices, and was last updated 13 years, 10 months ago by
iamaran.
June 8, 2012 at 11:26 am #69848
iamaran
ParticipantZanussi ZWF 1430 – 7 years old.
Was getting noisy last week. We’ve been away for a week and now it fills up and goes through a cycle (the minutes remaining counter goes down) but the drum doesn’t turn.
By hand with the machine turned off I can turn the drum approximately 1/8th of a full circle in both directions.
Pressing start and reset sometimes gives error E11.
Thanks in advance for any advice.
June 8, 2012 at 11:30 am #376179kwatt
KeymasterRe: Zanussi ZWF 1430 Drum won’t turn
E11 should be a fill problem.
The drum not turning could be something stuck in the drum, motor, bearings… you’ll have to open it up and have a look see.
June 8, 2012 at 12:11 pm #376180iamaran
ParticipantRe: Zanussi ZWF 1430 Drum won’t turn
Thanks for the reply.
Yes, I found with a search that E11 should be a fill problem, however it is filling and emptying just fine.
I’ll look for anything obvious. What’s the best way in?
June 8, 2012 at 1:18 pm #376181kwatt
Not sure but most of them are split cabinet, so lid off and the cabinet splits in two.
June 8, 2012 at 3:05 pm #376182iamaran
Lid off, and the first thing I see is the belt which has fallen off! Is there a way to get it back on without splitting the machine in half?
June 8, 2012 at 3:11 pm #376183kwatt
Not without huge difficulty, no.
June 8, 2012 at 3:11 pm #376184iadom
ModeratorRe: Zanussi ZWF 1430 Drum won’t turn
The belts don’t ‘fall off’ without good reason.
If the drum will not spin, smoothly and quietly with the belt off then you have big problems.
Either the drum bearings have failed or there is something jammed between the inner and outer drum.Major strip down and possible expense involved. 😥
June 8, 2012 at 3:25 pm #376185iamaran
Okay thanks guys. With my limited abilities are we basically saying scrap it?
UPDATE – the drum now turns freely by hand so likely the belt was preventing it before?
June 8, 2012 at 8:30 pm #376186iadom
If it spins freely and more importantly quietly then it could just be a faulty belt. Refitting the old one is a waste of time. Rear half of cabinet has to be removed to fit new belt.
If there is any noise then it’s likely the bearings have failed, there should be virtually no noise when spinning the drum if the bearings are sound.
June 8, 2012 at 9:10 pm #376187iamaran
Rear half of cabinet off, old belt back on (I know you said it was pointless iadom but it’s all I have).
It filled, then errored. It was noisy, but the belt is still attached.
By hand the drum still moves freely. You can hear a noise, but it’s not very loud and it doesn’t sound like anything is too amiss.
Thanks everyone.
