Re: Zanussi ZWF 1430 E90 code
all the E90 codes relate to pcb errors e90 is shown on display and you can only see correct code by going into engineering or service mode
E91 & 92
Communication error between main PCBdisplay
board
(versions not compatible)
E94 Incorrect configuration of washing cycle
E95 eprom communication error
E97 prog selector and cycle config error
try the following
disconnect wire leading to display module from main pcb
turn on machine wait 5 secs and turn off again
reconnect wire and turn on
may not work but worth a try
