Zanussi ZWF 1430W flashing lights code ERR / 2.02
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi ZWF 1430W flashing lights code ERR / 2.02
  • #84995
    ath007
    Sister’s Zanussi ZWF1430W powers up but when any of the buttons on the facia are pressed the lights associated with that button flash/bleep rapidly 3 times.
    Reset Button found stuck in so repaired.
    Problem as described persists and as the lights flash the display switches from 2.02 to ERR then back to 2.02
    Any help/advice greatly appreciated,
    Arthur
    #427395
    Re: Zanussi ZWF 1430W flashing lights code ERR / 2.02
    this is a long shot but have had connection problems on the front panel of this type of machine before
    there is a 4 wire lead going from the main board to the front user panel. unplug machine,disconnect this lead. plug machine back in , turn machine on, wait 10 secs, turn machine off and unplug, reconnect lead, switch on and try
    ath007
    REPAIRED!
    Did exactly as you said and all is now hunky dory.
    Many, many thanks
    Arthur
