Zanussi ZWF 1432W washing machine
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi ZWF 1432W washing machine
  • #79955
    Gassius
    I have the above washing machine and during any wash cycle, with normal load, seems to randomly try and spin during mid cycle and then stops and pauses. Sometimes it will almost jump across floor, other times start/pause button will flash and i have to turn machine off and on again and reselect cycle which then continues from where it was in the cycle. There seems no pattern to it and when empty goes through cycle fine. Is there some sort of load sensor on this model? I’ve tried resetting PCB via reset button and the master reset cycle of machine off for a minute, back on then open and close door 6 times but to no avail……. Any advice welcome, thanks
    #411175
    Seamy
    Re: Zanussi ZWF 1432W washing machine
    I’d think the tacho, coil & cabling from motor to P.C.B would be the first things to check.
    Have had to get some replaced during warranty for doing the same, software glitch i’d imagine though.
