Zanussi ZWF 1437 W – Noisey Spin
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi ZWF 1437 W – Noisey Spin
  • #47383
    Pidsley
    Very noisey when spinning. All functions ok, no leaks. Mqchine 4 years old.
    Is this a bearings problem, can they be replced?
    #293299
    martinm
    Re: Zanussi ZWF 1437 W – Noisey Spin
    sounds possibly like bearings big job though
    #293300
    Pidsley
    How can i find out if the bearings are diy replaceable or whether they are the sealed unit ypes I’ve heard about that basically means a new machine?
    #293301
    Remove the mains plug and take the top off, if it looks like the drum in the picture in THIS article then its a sealed drum.
    That said even if it is one on which bearings can be changed it is not really a simple DIY job. Quite a long involved strip down which can turn out to be very expensive if the drum shaft is damaged.
    PS. I will move this to the ‘WASHING MACHINE’ forum, Unless you are actually using it as a dishwasher which would explain thie noise. 😆
    #293302
    Pidsley
    Ok so is it worth getting it fixed by an engineer.
    What sort of cost am I talking about.
    Not looked whether sealed or not yet.
    #293303
    Just checked on that model number and some of them have the split tub and later ones have the all in one welded tub. :rolls:
    Tough call really, welded tub, possibly not worth it, split tub depends on how long it has been left with the bearings making a noise. A major strip down either way but not easy to tell if the drum shaft is damaged until you open it up TBH.
    #293304
    helo_75
    you cant buy a welded tub
    service parts are tub inner, front, rear, seal, 17 bolts
    VERY costly
    #293305
    Pidsley
    Sounds like a new machine then. What a rip off. Serial number 70700270 model number 914522201-01
    if that sheds any light on it.
    #293306
    Not really – you’ve a machine manufactured down to your budget and you bought it.
    Set your budget somewhat higher and do your research. As an ISE agent, I would point you at http://www.iseappliances.co.uk – our machines don’t suffer these problems.
    You absolutely will get what you are prepared to pay for.
