Hi, I seem to have a problem with my Zanussi washing machine. It just seems to stop during the rinse cycle and when I move it along to rinse it stops during that as well. When I move it to spin, it works but then stops 2 mins from the end of cycle.
There are no error message and the m/c fills and emptys ok and also spins ok.
When the m/c stops due to the fault the time does not move on.
Update- just run the m/c empty and it went through the whole cycle without stopping.
Does this machine have carbon motor brushes as I thought they could be worn so it runs on fast continuous spin but not on slow spin during washing and the fact that it runs ok empty?
If there are no error messages shown, it could be a number of things from motor brushes to the pressure sensor &/or switch to the heater to the main board. The codes the user usually sees are: E10 (fill problem) E20 (drainage problem) E40 (door problem & E90 (electronics problem).
