Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › zanussi zwf 14581 diagnostics
- This topic has 5 replies, 3 voices, and was last updated 15 years, 5 months ago by
buzzard.
October 27, 2010 at 8:11 pm #58360
buzzard
ParticipantJust left above machine with continual drain pump- spent hour on it covered everything and still totally flummexed-reading threads it appears putting it through dignostics and resetting could solve my brain ache.
Is anyone in aposition to forward diagnostics info to me please?October 27, 2010 at 8:41 pm #334317BobHope
ParticipantRe: zanussi zwf 14581 diagnostics
insulation fault on the heater causes this, just disconnect the heater and see if it works, or better still do an insulation test with a decent insulation tester.
Bob.
October 27, 2010 at 8:54 pm #334318gandh1
yes dont forget about the diagnostics!!!
should be freely available if you have a connect account and pnc 🙂
otherwise pm me your email…
thing is constant drain is the machine in like a safelock mode, whyby almost anything electrical in it will cause this symptom :bang:
once u have the diagnostics what you need to do is:
read last error code first – (match up with error description, and check component(s) associated, replace if necessary)
clear last error code
run full diagnostic test routine.
and so on…
laborious but usually useful.
October 27, 2010 at 9:49 pm #334319buzzard
many thanks Bob & Ghand1 for responses- found info needed, eventually on mediator with connect.
Going back on Friday- will hopefully post successful outcome then.October 28, 2010 at 10:48 am #334320gandh1
just be aware that there can often be more than one error code, so you might have to keep replacing and clearing error codes until the dignostic test run shows you E00 on position 10
October 29, 2010 at 5:13 pm #334321buzzard
Thanks v much. insulation on heater .4meg- disconnected and machine kicked into life.
Didn.t show low reading other day as swung through from plug top- relays not energised then though!!! I feel they are overengineered appliances nowadays,bring back mechanical timers.
New heater ordered- happy customer!!
Cheers. -
