zanussi zwf 14581w washing machine error 59
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries zanussi zwf 14581w washing machine error 59
  • #75346
    frogger
    Hi can anyone tell me this error code much appreciated,
    #394617
    Hollytree_Technical
    Re: zanussi zwf 14581w washing machine error 59
    No Signal from the tachometric generator (the signal must be absent for at least 3 seconds)
    Jem
    #394618
    frogger
    Hi Jem I went through the test sequence to find fault and thats the error i was getting,When I checked the machine I noticed the drum was seized solid would that be the reason cheers,
    #394619
    Hollytree_Technical
    Sounds very possible – if the drum was seized and it has a good belt on it then it could also seize/jam the motor which would stop the motor generating a tacho signal.
    Jem
    #394620
    frogger
    motor was fine and also the belt
    #394621
    Hollytree_Technical
    Does it still throw up the error after unsiezing the drum?
    Jem
    #394622
    frogger
    cant free it is solid
    #394623
    As you now appear to have trade access I have deleted your question about this machine from the public forums.
    #394624
    frogger
    no problem,
    #394625
    Hollytree_Technical
    Remove the belt, clear the error and then see if it brings it up, my guess is that it won’t come up as the motor will be able to turn again.
    If you are lucky then it will be just something like a stone or sock jamming the tub (Yes I have had a sock jam a drum) otherwise it is a case of replacing the bearings (or tub if it is a sealed tub).
    Jem
