zanussi ZWF 1630W -all program buttons do not work/light up.
Home Forums Public Support Forums Help And Support Washing Machine Help Forum zanussi ZWF 1630W -all program buttons do not work/light up.
  • #38957
    toolefamilyw13
    I set the machine off last night and when i came down this morning it had stopped before spinning. There was water in the drum and although the power on/off light was on none of the program lights would come on. Any ideas where to start looking. Thanks
    Edit: The power switch turns on the power light but this does nothing.
    #260481
    helo_75
    have you made sure the rinse hold option isnt activated?
    other than that, try the obvious ( the pump filter)
    #260482
    Re: zanussi progress 1600
    Model number………..
    toolefamilyw13
    Re: zanussi ZWF 1630W – programmes have gone dead
    ZWF 1630W
    We have cleared out the filter and let the water flow out from the drum. Despite removing a small fortune in pennies from the filter (could this make the water overflow thus damaging the electrics?) nothing has changed 🙁
    #260484
    That was a crafty edit you stuck in there……… 😀
    If the facia will not light up at all, it’s possible that the cabling from the computer board is faulty; otherwise the computer board itself would be my main suspect.
    toolefamilyw13
    Oh! That cant be good.
    How can i make sure that i get the cheapest most effective remedy to this.
