Zanussi ZWF 1631 stopping.
  • #45384
    effzedarr
    ZWF 1631 prod #914516328/00,customer complaining of the machine stopping mid cycle but not every time (typical) anyroad i went into diagnostics & it came up with E91 which under AEG error codes means bad comms between boards or pcb.I went through diags again & E90 came up but carn’t find that code so re did it again only for ELE to come up & then the m/c started to fill for about 30secs then stop dead?? :rolls: WTH???.Switched off then back on to spin & empty which took the best part of 10 mins with no spin at all just tumble & empty for 1min then stop for 1min. All the while this is going on i can hear a faint hiss/buzz from the pcb 😯 , i’m got to be thinking the pcb. Your thoughts please..
    Regards Chris…
    #285516
    Re: Zanussi ZWF 1631 stopping.
    e91 you are correct lists faults as Wiring faulty; Faulty control/display board Main PCB faulty.
    fault e90 if this was on the display the cutomer would use this makes sense if you go into diagnostics will then give true code
    have a word with emw see if they have tests for panel yet
