Zanussi ZWF-1631W Leaking After Cleaning Pump
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi ZWF-1631W Leaking After Cleaning Pump
  • #48380
    Ziemas
    Hello All! My Zanussi ZWF-1631W washing machine is leaking water from the bottom of the machine immediately after starting a cycle. The leaking happened after I cleaned the pump, which had been making an odd noise. In the pump impeller I found a coin and a cigarette filtre, and the emergency emptying hose was blocked. I blew out the emptying hose after cleaning the pump impeller and testing the machine, which was leaking.
    Could someone please advise me on the possible causes of this and the remedy?
    Thank you very much for the help.
    Ziemas.
    #296447
    helo_75
    tilt it back and put the small drain pipe back on the pump housing 😉
    #296448
    Ziemas
    helo_75 wrote:tilt it back and put the small drain pipe back on the pump housing 😉
    Thanks for the quick reply! I’ll give it a try and report back.
    #296449
    Ziemas
    Re: Zanussi ZWF-1631W Leaking After Cleaning Pump
    It was a simple five minute repair (including taking the door frame off the bathroom to get the drier out to have some room to work), and couldn’t have been easier.
    Thank you very much for the excellent help!
    Z.
