Zanussi ZWF 1632
  • #66323
    Robjones
    Zanussi ZWF 1632.
    I have a problem with the above machine stopping after wash cycle, wash light on and nothing else flashing. Sometimes stops with wash, rinse and spin lights on with start light flashing. Turn power off/on and skip to next step and then finishes as normal.
    Stops after draining water so pump ok, checked drain pipe and pipe to pressure switch – both clear.
    Any ideas?
    #363795
    Seamy
    Re: Zanussi ZWF 1632
    Maybe motor brushes worn, power off while working on it!
    #363796
    Robjones
    Thanks for reply.
    Checked brushes this morning, look ok. No signs of arcing and approx 20mm left in brush holder.
    Whilst machine was apart cleaned all connectors with electrical cleaner to see if this helps.
    What’s the average call out charge for an engineer? Just weighing up if to call someone out or replace machine.
    #363797
    Robjones
    Still the same, did an empty wash ok after I put it back together but failed tonight on a wash with clothes in.
    Back to the drawing board.
