hi gents
called to a zanussi can select prog start to pump for a couple of second as normal then goes to end of programme drianing for a minute and end of programme this is on all programmes even spin only.done a test; water valves ok, motor ok, when on heating test the regen pump come on but no heat e35 or e33 on error code tested p/s ok, any ideas ive ran out of them
alro
Re: Zanussi ZWF or S 1650 go to end within seconds
Chris
turned out to be a dry joint on the main pcb
thanks for the file i have a different email address but do not know how to up date it on this site thanks again as suggested by paul PGS
cheers alro
