Zanussi ZWF1007 diagnostics
  • #54996
    DOCTORDOOM
    I’ve got one of these constantly pumping. PNC 914206107. Is the test program the same as the one for the tricity AW1400 posted in the known test procedures?
    #321660
    aqualectric
    Re: Zanussi ZWF1007 diagnostics
    Press and hold the start / pause button and the next option button to the left of it. Turn dial one position. This puts the PCB into diagnostic mode. Codes are give or take the same as all Zanussi machines ie: same as the Fault code book and Known Error Codes thread. Tenth position on the dial is the last recorded fault code and also the fault code erase position. 1 – 9 are the component test phases.
    Hope that helps,
    Steve.
    #321661
    DOCTORDOOM
    I think that WILL help.Thanks for the reply.
    #321662
    This might be relevant.
    Mike.
