zanussi ZWF10070W1 not programming
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries zanussi ZWF10070W1 not programming
  • #44708
    Geoff1312
    Hi All,
    Help required once again please. The above machine you can set the programme, Panel lights up correctly, Once start is pressed pump runs as normal but that is it, pump just keeps running. Have tried several different programmes including spin still the same. No fault lights.
    Any ideas please
    Thanks in anticipation
    Geoff
    #282017
    Specialist01269
    Re: zanussi ZWF10070W1 not programming
    Had this a couple of times in the last few weeks, both times it was caused by the heater being leaky to earth.
    Andy.
    #282018
    Seamy
    Or faulty analogical pressure sensor, they are giving a load of problems too.
