zanussi zwf1010w
  • #41193
    tedd
    hi all.got a call to above machine,the door locks pump starts to run for approx 3secs then cuts out and nothing else happens.anyone any ideas regards tedd.
    #269095
    funkyboogy
    Re: zanussi zwf1010w
    MORE THAN LIKELY THE PCB,
    watch out as it may have been another component thats taken in out,
    have a look at pcb , if tracks blown trace wiring connector where tracks blown to what ever component it runs to ?this normally gives you an indication of where to look for faulty component,
    top breather hose comes loose causing water to leak onto pump, pumps then takes out pcb..
    may be lucky and its just pcb failure, but defo worth taking a good look
    ally
    #269096
    Minge
    Possibly the recirculation pump.
    #269097
    alro
    try cold water valve
    alan
