Zanussi ZWF1020W
  • #15828
    Machine will not do anything, End light flashing 11 times, I have printed out the Diagnostics System. Any pointers before I return?
    #166513
    Beever
    Is it possible that this appliance is in a damp enviroment ie a cellar. the pcb is easly damaged via damp/ moistre. be careful if ur replacing the pcb as this will happen again if in a damp place!
    #166514
    farmboy
    Re: Zanussi ZWF1020W
    Check the supply voltage first, otherwise it sounds like the board.
    #166515
    Bone dry utility room in modern house, will bear your suggestions in mind though, going back tomorrow morning.
    #166516
    Bummer. Just cannot get the machine into diagnostics cycle. Press the Start/Pause plus other option button, select first position and after several seconds ( more than 2 seconds) the only light that flashes is the ‘End’ light. It is still flashing 11 times, nothing else happens. module faulty????
    #166517
    iadom wrote:Bummer. Just cannot get the machine into diagnostics cycle. Press the Start/Pause plus other option button, select first position and after several seconds ( more than 2 seconds) the only light that flashes is the ‘End’ light. It is still flashing 11 times, nothing else happens. module faulty????
    I’ll take it from the absence of replies , that you all agree with the diagnosis. ❓ 🙂
