Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Zanussi ZWF1020W Auto Not Starting… See Photo
- This topic has 3 replies, 2 voices, and was last updated 13 years, 7 months ago by
laurenceuk.
August 30, 2012 at 8:16 pm #71230
laurenceuk
ParticipantHi,
914780727/00
On pressing start button pump operates for a few seconds, stops and no fill occurs.
Door locks ok. No supply to valves.
Turn dial to off then select a rinse and machine fills. No motor action.
Select spin, machine empties and spins. If I allow the machine to fill in the rinse, select off then select a wash, it pumps out for about 15 or so seconds and stops with water left in. Turn selector off and back to the wash it will pump out again for a shorter period. I keep doing this until empty but again will not fill.
I selected the diagnostic function by pressing start/pause button and an option button and turning selector to right (I have no instructions for this – guessing). It started to impulse through the LED’s ok.
Turned to other setting then start/pause button LED and ‘end’ LED flashed a 4 flash sequence with the, ‘end’ LED doing an extra one. (see photo)
Is this a fault code and because all components are functioning ok do I suspect the control module?
Laurence
August 31, 2012 at 12:48 am #380412leavemetogetonwithit
ParticipantRe: Zanussi ZWF1020W Auto Not Starting… See Photo
E54 Description: Motor relay contacts sticking. Possible fault: PCB faulty; current leakage from motor or from wiring. Action/machine status: Cycle blocked, door locked (after 5
attempts)
That’s from PDF I downloaded earlier today for a ZWF1432 but I’m sure it’s the same reasoning.
Mike.August 31, 2012 at 6:21 pm #380413laurenceuk
Thanks Mike,
My conclusion then, it is the PCB.
If the time you posted is correct, you ought to get some early nights 😮
Thanks again,
Laurence
August 31, 2012 at 7:12 pm #380414leavemetogetonwithit
Laurence
Not necessarily. As the service manual said. 😉
Thanks for the reminder about early nights. I had a couple a week ago when I was a bit down. Feel much better for it.
Mike. -
