Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Zanussi ZWF12070W taking 2 attempts to start
- This topic has 5 replies, 3 voices, and was last updated 15 years, 2 months ago by
sparkyboy22.
January 25, 2011 at 7:24 pm #60514
sparkyboy22
ParticipantHi
Sorry to sign up and come straight in with a problem.
Got the zanussi mentioned above. About a week back it started needing the start button pressed twice before it does anything.I load it up, select the program and press start.
I hear the click which I guess is the door lock engaging and then a few seconds later the start button starts flashing again.If I start it the second time it starts as expected and the full cycle completes without issue.
It just needs to be started twice every time.
Any ideas what might be wrong or anything to check.
I have switched it off at the mains and left it off for about 12 hours and no change.Thanks in advance.
January 25, 2011 at 8:16 pm #342525Seamy
ParticipantRe: Zanussi ZWF12070W taking 2 attempts to start
It might be a door switch problem or could be board fault or button issue, or cable to door interlock either.
January 25, 2011 at 8:18 pm #342526sparkyboy22
Ha, nice and specific.
I have no idea what I am doing with a washing machine.
What should I do/look for?January 25, 2011 at 8:39 pm #342527Specialist01269
Hi: In all honesty, if you don’t know anything about Washing machines your safest bet would be to look for a repairer local to you.
You could also try looking in the repairs at feature of UK Whitegoods.January 25, 2011 at 9:35 pm #342528sparkyboy22
I’ve no issue taking my computer apart and had no issue with changing the engine on my car, a washine machine cant be so complicated.
If only they did Zanussi Haynes Manual!
Just after some hints before I take it apart.
January 25, 2011 at 11:15 pm #342529Specialist01269
You may not have an issue with takeing your computer apart, but by your own admission you know nothing about washing machines. If you open your machine up & do the wrong thing you could easily Electrocute :zap: yourself, in his reply to your original question Seamy gave you the possible causes of your problem. Unfortunately it could be any 1 of the items listed & you need to go through them with a test meter to locate your problem, to do this you need to know how each item is supposed to work or react when tested.
