zanussi zwf12070w1
Viewing 15 posts - 1 through 15 (of 15 total)
  • #66031
    adv
    this washer just emptys on every programme . wont fill or spin carbons fine only 3 year old any clues lads?
    #362797
    A1engineer
    Re: zanussi zwf12070w1
    dodgy pressure switch, might just need reset tho.
    Kevin.
    #362798
    adv
    wat needs reset the pressure switch? how you do that like? took pressure pipe off , still same .have reset the programme still no joy
    #362799
    A1engineer
    zanussi zwf12070w1
    No reset machine, Stick the machine in test mode run test, it will reset at end and might work.
    If not replace presure switch.
    #362800
    bigchrisoioi
    whats the error code?
    #362801
    adv
    dont no how to get error code on this model? how do you get into test mode? tryed start and option button held in before turning on na joy?
    #362802
    bigchrisoioi
    easier than that….start the program and as it starts to run hold the start and the button to the left of it together for a few seconds and the display will show the code…let go of buttons and it will disapear just after….
    #362803
    adv
    ok cheers al try that moro. ta
    #362804
    adv
    are the pressure switches prone to goin on these machines?
    #362805
    gandh1
    yes, along with module, interlock, solenoids, motor and drum,
    to put it mildly the 12070s were runts of the elux litter
    #362806
    Found this for you adv
    http://www.ukwhitegoods.co.uk/forumsphpbb3/viewtopic.php?f=3&t=44141&p=230424&hilit=continuous+drain#p230424
    but this fault is quite common and I wouldn’t rely too heavily on the info. therein. Maybe EMW do these boards now.
    Mike.
    #362807
    adv
    ok cheers lads zanussi hate there stuff anyway
    #362808
    adv
    another one of these a john lewis make tho doin exactly the same but shows e21 pump runs fine tho and no blockages ? mmmm?
    #362809
    So is E21 a pump time-out then? I don’t know, not very familiar with that code. Could it be that the code needs clearing?
    Other than that, you have to ask yourself how does the machine “know” or “think” that the pump is blocked? That might put you on track.
    Mike.
    #362810
    adv
    dont no mate how do you clear the code ? e21 is ment to be pump out problem? i cant get it to change, when move timer times an that change. but just does same pump mmm ?
