Zanussi ZWF12070W1 won’t complete cycle.
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi ZWF12070W1 won’t complete cycle.
  • #94504
    Hazz3004
    Hi. I have a Zanussi ZWF12070W1 which has been in the property since since before I moved in a couple of years ago.
    Recently my washing machine fails to complete a cycle, the start/pause button just seems to flash.
    I’ve tried cleaning out the filter but this hasn’t sorted the issue.
    I have tried the error code thing of holding down the start button and option button then turning the option wheel 9 turns click wise. This gives the error code x1 red x3 green.
    Please help. First baby is due soon so would like washer up and running!!!
    thanks. Harry.
    #457532
    Re: Zanussi ZWF12070W1 won’t complete cycle.
    fault code 13 it looks like which is a fill time out. ie taking too long to fill
    make sure its not draining as its filling ( outlet hose too low or pushed down outlet pipe too far)
    check fill hoses for leaks and make sure tap is turned fully on
    that’s the simple things to check first
