Zanussi ZWF12070WI
  • #59503
    Taff
    Went to look at this machine after customer reported a blocked filter. On selecting a program the machine pumps out for a minute or two then switched to end of program. I entered the test cycle and the error code flashes four red then 3 green on the start/pause button. Does anybody know what this error code is?
    Regards
    Taff
    #338447
    Criscold
    Re: Zanussi ZWF12070WI
    Interlock power supply triac faulty – you have mail
    Good luck
    #338448
    bigchrisoioi
    change the door switch!!!….they have had problems with certain interlocks…it wont be the PCB!
    #338449
    gandh1
    how can you be certain it wont be the pcb as well? these dodgy interlocks love popping triacs. its a bit of a fiddle, but 10 mins checking board as well is worthwhile, if only to guard against an extra re-call. and emw will fix them if it has blown.
    elux pcb manual available on mediator with pictorial segregation of components, to aid where to look on board
    #338450
    Taff
    Went back to the job the triaic was blown board on its way to EMW and a new door switch on order. Thanks for all the advice. Regards Taff
