Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Zanussi ZWF12080W
- This topic has 6 replies, 5 voices, and was last updated 16 years, 3 months ago by
TonyMower.
December 30, 2009 at 8:34 am #51251
TonyMower
ParticipantIm looking for any error codes for Zanussi washing machine module number ZWF12080W.
Any help with this would be great.The problem im having is this is a brand new machine, just installed and used for first time. programe selected, wash light comes on, door lock light comes on, door locks and then just sits there doing nothing at all for approx 30 seconds then door lock light flashes. Nothing else happens.
Regards
December 30, 2009 at 10:13 am #307387electrofix
ModeratorRe: Zanussi ZWF12080W
have no info on this machine too new but
1 if its that new send it back dont touch it why should you
2 if its thje same as the 12070 machine alarm codes are from the start pause button flashing red and green red fist digit green second digit of fault code door problems are e4* fault codeshope this helps
December 31, 2009 at 9:36 am #307388Seamy
ParticipantRe: Zanussi ZWF12080W
After it locks the door drain pump should run which you should hear, then water intake, or you should hear solenoid humming anyhow. If its newly installed i’d be looking at tap for water not turned on or if its connected to drain spiggot on sink its likely the cap is still on spiggot. Kinked hoses would gave same faults.
January 4, 2010 at 10:33 am #307389TonyMower
Definately just does nothing at all after door locks, no humming/buzzing of pump or solenoids at all. I was thinking faulty module?
Appliance purchased from a third party and we repair all their appliances for them, they dont worry about the garuntee/warranty.
January 14, 2010 at 11:10 am #307390TonyMower
ParticipantFinally got this machine back to the workshop, does anyone know the test procedure if there is one for this appliance?
January 15, 2010 at 1:57 am #307391leavemetogetonwithit
Have you got an account with Connect Distribution? The info is all on their site. Or PM me with your e-mail address.
Mike.January 15, 2010 at 2:04 am #307392aqualectric
TonyMower wrote:…..programme selected, wash light comes on, door lock light comes on, door locks and then just sits there doing nothing at all for approx 30 seconds then door lock light flashes. Nothing else happens.
Motor brushes or PCB……probably the latter…… 😥
Steve.
