Zanussi zwf12170w keeps pumping
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Zanussi zwf12170w keeps pumping
  • #68370
    allan
    Hi, have problem with above machine, will only pump wherever it’s set, is there a reset procedure or test cycle? Its not got a digital display.
    Thanks Allan
    #370778
    jimca007
    Re: Zanussi zwf12170w keeps pumping
    unfortunately very likely to be the surface mounted triac on the main pcb which turns the pump on and off had a few of these short out see her for diagnostics and fault codes
    http://www.electrolux-ti.com/others/599/724/080EN.PDF
