the display on this machine is showing 138 and it is set on the synthetics prog (2nd light down) 40 degree (4th light down) with 900 spin (2nd light down) but it wont start or change prog no matter what buttons i press i cant change it! 😕
any ideas or is it just the usual pcb fault?
Normaly if you switch “OFF” machine from I/O button he should reset himself. If it’s comming back in same situation (same program activated) then something happen on front panel electronics… I do not know what, it never happen to me…
