Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Zanussi ZWF1220w Will not pump out when put through a progra
- This topic has 12 replies, 7 voices, and was last updated 15 years, 6 months ago by
Bernie.
September 30, 2010 at 6:18 pm #57627
Bernie
ParticipantWill not pump out when put through a program finishes with water and very wet washing, works ok if you put it onto spin. Any suggestions or ideas
Thanks BernieSeptember 30, 2010 at 6:29 pm #331766geoff1
ParticipantRe: Zanussi ZWF1220w Will not pump out when put through a pr
Bernie
Can I ask if the end light is lit to show that the machine has completed the cycle or is the start light flashing.
I ask this as I have had several where they abort the programme during the cycle with the start light flashing. User believes that the cycle has completed but clothes are still wet or even water in the drum.
When you do spin it works okI have found either the motor toc or the module causing this.
Geoff
September 30, 2010 at 6:45 pm #331767Bernie
I haven’t seen the machine after it has done this only got what the customers has told me and she never said if the end light was flashing, I will have to ask
Thanks for the quick reply GeoffSeptember 30, 2010 at 7:14 pm #331768geoff1
Sorry
Forgot to mention to check to heater insulation as well
Geoff
September 30, 2010 at 7:22 pm #331769Seamy
Filter or sump hose or pump blockage perhaps
September 30, 2010 at 9:20 pm #331770Bernie
I tried it by starting it on a wash program with clothes in it and then turning it to spin it empted and spun just fine. The clothes had spun dry
Thanks Bernie
October 3, 2010 at 12:36 pm #331771gandh1
so the o.o.b control kicked in then???
October 4, 2010 at 9:06 am #331772electrofix
ModeratorRe: Zanussi ZWF1220w Will not pump out when put through a pr
take it you asked about rinse hold facility
had a few customers who changed cycles used and thought it was a fault
October 4, 2010 at 7:53 pm #331773Bernie
I now have this machine in my workshop and have tried it three times before it finished full of water and the end light just on and not flashing.
I have not had time to investigate further but my first thought is pump toc operating.
Have printed out the Instruction Book for this model so as to know which programs it does not spin on or have rinse holdBernie
October 5, 2010 at 7:23 am #331774Martin
Knackered pump!
October 5, 2010 at 7:39 am #331775Bernie
Thanks for that Martin
October 5, 2010 at 9:00 am #331776pup
main motor?
October 15, 2010 at 5:15 pm #331777Bernie
Finally got to the bottom of this one it was the pcb.
Thanks to all off you for your help and suggestions
Bernie -
